71 duster manual steering
Hello everyone I have a 1971 duster roller that I bought a couple months ago the previous owner was in the process of switching over from ps to manual I believe most of it is there but I am not certain I believe he told me everything is there except the idler arm? I am not sure if that's the right name or part just what I believe he said he mention something about the one that's one there no is facing the wrong direction? I'm not sure but was wondering if anyone can help me out with getting the right part or part number for what I am needing so I can put the steering back together and get ready to drop a engine into it thank you for any and every response
https://cimg2.ibsrv.net/gimg/moparfo...d54abd0194.jpg https://cimg4.ibsrv.net/gimg/moparfo...587c50275c.jpg |
Pitman Arm for a Manual Steering Gear.... Also may need a new Steering shaft to Steering Gear Coupler. Should be good to go after that.
I believe I have the coupler so the pitman arm are they all the same as long as its for an A body manual steering and year? Because the manual gear box has one on it already I just don't know if it came with the gear box or the previous owner thought the power steering gear box pitman arm would fit and tried putting it on the manual one but I mocked it up when I first got the vehicle and it's definitely not the right pitman arm
Guess you will just have to try them... Or look them up at Napa auto parts and see if you can figure out what ones you have or need. May even have to check the drag kink?
Some mopars have different columns for manual and power steering…
