73 dart 4 door 440 swap
Old Feb 25, 2022 | 04:58 AM
87w150's Avatar
I recently bought a 1971 440 and while looking for a vehicle to put it in stumbled across a 73 4 door dart /6 and was wondering if anyone had put a 440 in one and if so what does it take
Old Feb 27, 2022 | 08:18 AM
Not a direct swap. But if you have fabrication skills and a budget it can be done.
Old Feb 27, 2022 | 11:44 AM
Building or modifying motor mounts will be your first hurdle after locating motor and transmission in the correct place.. Motor needs to be offset the same amount as the transmission. Exhaust is the next thing,, the one and only Abody I swapped I've done I used Hooker fenderwell headers and the radiator that came with the 440. A Bbody 8 3/4 rear axel assembly will get you close and I cut down a drive shift from a full size mopar.
Mine was a 67 Valiant 2 door, a fun car.
EduardoIbarra
Oct 17, 2017 10:24 AM
Leaningtowerofpower6
Oct 10, 2016 10:13 AM
MrChris
Oct 16, 2013 08:30 PM
moparjohnson123456
Jun 14, 2011 01:45 PM
