73 VALIANT BOGGING AROUND TURN
Hi new hear my name is brad and im a junior in highschool.
I have a 1973 plymouth valiant with a 225 slant six with a one barrel holley carb. The car runs great when im cruising or throttling it hard until i go around a turn and throttle it, it boggs or tries to stall. This also did this with a full tank of gas so i dont think it was fuel level. Also the fuel pump is new, fuel filter, carb, and vacumme is routed correctly i believe. Any ideas guys or gals? |
I assume you have power steering, as I see this when I turn the wheel all the way to one side.
What you should do is check your fluid level in the power steering and possibly change it out. |
does it act worse turning into a curve either way?
Originally Posted by Commando
(Post 6888)
Originally Posted by ef8340
(Post 6909)
I am not sure, I just know it happens, I assume that there is more resistance in the power steering causing the belt to spin slower and in turn bogging down the engine. Same thing happens in my 98 truck if I turn the wheel all the way.
(Post 6921)
Turning right wasn't a problem at all. Bob |
(Post 6921)
I never knew why, but I had a 1974 Duster that stalled every time I made a left turn unless I accelerated at the same time. Turning right wasn't a problem at all. Bob |
| All times are GMT -7. The time now is 02:20 AM. |
