Can I wire a 5 pin box like 4 pin?
Old Jun 14, 2013 | 07:30 PM
tmatador's Avatar
70 Duster 340 with a electronic ingnition from a 75 D100.
The car runs starts and runs fine cold. It will still start after letting it sit and idle for a few minites but if I drive just a couple miles and shut it off its not going to start for an hour or so.
I have changed the spark module, ballast resistor, wires, cap,rotor button, plugs and a new coil.
Still wont start hot so I got to tracing wires and it looks like whoever made the swap to electronic has it wired like a 4 pin module instead of a 5 pin (it is a 5 pin module) The wire for pin 3 is cut on the module and the wire I think should go to pin 3 from the resistor is cut. Could this be the issue? Maybe i'm wrong? Thats why i am asking if it would even start even cold if this is what they have done?
Attached Thumbnails Can I wire a 5 pin box like 4 pin?-img00098-20130614-0846.jpg
Old Jun 14, 2013 | 08:29 PM
moe7404's Avatar
check out post "checking points & condenser" by 440roadrunner #16. roadrunner lists all the info you need. his post should be a sticky
Old Jun 20, 2013 | 04:12 PM
moe7404's Avatar
well the thanks goes to roadrunner.
76NY440_nTX
Jun 12, 2011 04:27 AM
fivepoint
Jan 15, 2011 07:33 PM
Mango
Jan 2, 2011 11:23 PM
getsum
Mar 25, 2010 07:31 AM
johnthegoalie
Feb 28, 2009 11:54 AM
