coolant on the ground two puddles
So i have been driving my dart a little bit every week and today is the first day that it had two puddles on the ground after i drove home from work. it leaked from the side tub thing below the cap. am i missing a overflow line that is supposed to be there? it has never done it before and it runs cool plus it has a new radiator, i am running a 14 psi cap as well.
yeah there should be a line running into an overflow tank from that hole below the cap.
thanks man ill look into getting one since mine has gone missing apparently
my -
If that's it, you might also want to look into an over-flow canor "puke can", if there isn't one there already. If you can find one that has the over-flow hose going into the bottom, better. Archer |
Thanks man, yeah im learning this mopar as i go, were the original overflow tanks recirculatory systems? i found some overflow tanks made out of nice aluminum that are polished and look sharp
| All times are GMT -7. The time now is 05:33 AM. |
