Electrical issues
Old Aug 15, 2022 | 05:02 PM
darty74's Avatar
Electrical issues
Hello everyone,
I am working on a 1974 dart custom 4 door 318 automatic transmission. I just recently rebuilt the top end and had it running really well. I left to go put fluids into it and come back after refilling try to start it and it wouldn't start And on the 3rd try the wire from my starter relay to the plug in the firewall caught fire. Luckily it was just a fusible link and didn't do any damage. Either it is a 50 year old link or I have a short in the Ignition. Any help in figuring out the problem or directing me in the right direction for a differant inline fuse would be awesome. Thank you
Old Aug 17, 2022 | 02:52 PM
Try these...
Old Aug 17, 2022 | 03:13 PM
darty74's Avatar
So all of the other power wires come off the opposite side of the amp gauge is to everything else in the cab?
Old Aug 18, 2022 | 05:59 AM
How do you like them apples?
For the most part "Yes"
Do you have a wiring Diagram for your car?
IF not check here: it's free No Charge.. >>>>>> https://mymopar.com/wiring/
Old Aug 18, 2022 | 06:53 AM
darty74's Avatar
Is it possible for a Ignition switch to keep power from the rest of the car? I have been chasing wires for a week and can't find anything besides what I have replaced.
Old Aug 19, 2022 | 08:41 PM
If the fuse block is dead?
The fuse block gets power with the key and also from the amp gauge....
If you have power coming out of the switch them you just have to trace the wires to the problem....
If you dont have power at all to the switch or the amp gauge... Then you have to trace that back out to the engine compartment area possibly the fusible link....
Old Aug 19, 2022 | 08:44 PM
Once you have those powered up we can chas a not crank no start if that becomes a problem....
But you have what sounds like some dead wiring or connections that need to be found at the moment...
Will get there... Keep Chipping at it !!!!
Old Aug 19, 2022 | 08:51 PM
darty74's Avatar
[QUOTE=RacerHog;159797]Once you have those powered up we can chas a not crank no start if that becomes a problem....
Will get there... Keep Chipping at it !!!![/QUOTE
Thank you for your help! It's just weird how it was running and then it blew a fuse
Old Aug 19, 2022 | 08:57 PM
Ya. It just happens that way.... But look at the brite side..... It didnt catch fire and burn down to the ground !!!!!! That would have sucked....
Have you checked the amp Gauge? Power to both sides? They dont give you any warning at all when they go out...
Old Aug 20, 2022 | 12:24 PM
darty74's Avatar
I have access to the ammeter but can't figure out how to get a reading to the posts
Old Aug 22, 2022 | 08:53 AM
Use your test light... >>>>> https://www.lislecorp.com/specialty-...circuit-tester
Justin123shory
Feb 13, 2014 06:00 AM
duster fanatic
Jun 29, 2013 11:07 AM
dragonmwt
Sep 11, 2011 05:25 PM
jls
Feb 6, 2011 09:52 PM
mr_Sancho1324
Feb 3, 2011 09:05 PM
