ftmfw
Old Apr 19, 2009 | 01:35 AM
theomahamoparguy's Avatar
sweet deal. .... hey, we got your back man, no sweat, just throw it out there!
Old Apr 19, 2009 | 03:43 AM
any pics?
Old Apr 19, 2009 | 04:07 AM
Polaradude's Avatar
x2 on the pics
Old Apr 19, 2009 | 04:27 PM
3x on pics
Old Apr 19, 2009 | 07:33 PM
chlngr1970's Avatar
j
Old Apr 20, 2009 | 09:15 PM
johnthegoalie's Avatar
thinkin with me dipstick
pics?
Old Apr 21, 2009 | 04:39 PM
2x on pics
Old Apr 21, 2009 | 05:23 PM
Originally Posted by 8287rams
Now for the nitty gritty, I need expert advice on how to adjust the carb, it has the stock 2br,
I will also like to know what tool is needed to remove the valve springs with the heads still attached as it smokes quite a bit
To adjust the carb the best way is to use a vacuum gauge.
The two screws on the front lower part of the carb are the idle mixture screws. Try to get the highest reading on the vacuum gauge. Clockwise to lean it out and counter-clockwise to richen. The idle speed screw is on the driver side, this adjusts the rpms. 750? for idle. The other screw must be for the fast idle adjustment. This is the adjustment for when the chock is operating, when you first start the car. It idles faster when warming up.
To remove the valvesprings, there is a tool that is shaped like a prybar sort-of. It uses the rocker shaft fot the lever point. I cant tell you where to obtain one though. Youll also need to pump the cylinder up with air before you attempt the removal.
Old Apr 22, 2009 | 02:09 PM
DUSTERforLIFE's Avatar
ttest pic
Old Apr 22, 2009 | 03:55 PM
huh?
