fuel starvation
Old 12-21-2007 | 12:12 PM
This sounds like a case of what in the U.S. we call "vapor lock" which can have several causes.
The general situation is that heat causes the fuel to tend to boil. Because the normal fuel pump is engine mounted up front, the entire fuel line from the tank to the pump is under reduced pressure (suction) caused by the pump. THIS FACT causes the fuel boiling point to be lowered, and the fuel can "flash" or boil right in the fuel line, causing vapor which "won't pump", hence the name "vapor lock".
There are several things you can do to solve the problem.
First, inspect carefully the condition of the line. Start at the tank, and inspect the rubber connector, as well as the one at the pump. If these appear to be at all crimped, flat, soft, or damaged, replace. Inspect the metal line for damage, such as large dents or flattened. Look to see if the tube is close to heat, exhaust/mufflers, etc.
In some cases, the filter or tube in the tank can be damaged, rusted up, plugged, which causes a restriction.
It might just be the pump itself is weak. Just because you installed a new pump does not mean that it is working properly, or is of good quality.
I did not see your car model listed. Some cars, and Jeeps, have a "vapor return line" in the fuel system. This consists of a can or filter which is inline at the output of the pump, with a small bleed hole at the TOP of the can, returning to the tank through a second tube. This can collects bubbles and vapor and returns them to the tank
My '70 Roadrunner, which came from the factory with a "440 six pack" had this right from the factory. My '69 383 car did not.
One sure fire way to cure this problem is to install an electric pump RIGHT AT THE TANK, where the pump can "push" rather than "pull."
Take a GOOD look at all your fuel line, and isolate, move, or insulate it from exhaust and engine heat as best you can.
Don't wast time with wive's tales concerning "cow magnets" or other clip on devices--they don't really work.
Here is a diagram of a "universal" vapor return filter. IT IS UPSIDE DOWN. The small return fitting should be UP at the top.
http://www.autozone.com/images/cds/gif/small/0900823d8005150b.gif
Old 12-27-2007 | 08:44 AM
You might try a "hot run" with the fuel filler cap removed. You might have an incorrect cap, or a vent plugged up---you might be developing a vacuum in the tank
How did you inspect the tank?
The very least you should do is disconnect the fuel line from the tank and with a short scrap of hose, try blowing through the tube to see if it "feels restricted."
A BETTER method and the only sure method, is to actually remove the tank, remove the sender/ pickup assembly and inspect it. As old as all these cars are getting to be, the filter IN THE TANK as well as the pickup tube could be rusty and plugged
Another thing you might do is to "rig" a fuel pressure gauge as near to the carb that you can, and temorarily fasten (tape?) where you can see it, say, to a wiper arm. See if and how much the fuel pressure drops down
Now that you have an electric pump either:
You have a serious restriction in the line, or a plugged vent, or else it is NOT fuel, but rather, ignition or some other cause.
Old 12-28-2007 | 03:59 PM
Here's a few other things
First, did you try leaving the fuel cap off? This would tell you whether you have a vacuum/venting problem. That car should have a vent system tied in with the engine breather, so you might even have a hose incorrectly hooked to intake vacuum, when it should be hooked to the open breather. (Originally should have been a huge multiport breather on one valve cover, with several hose fittings)
You must not have a leak on the suction side of the line (from original pump to tank) because you did put an electric pump at the tank.
All I can suggest at this point is to take a real good look at the relationship between the hot exhaust and the fuel line.
Make sure you run a pressure / volume test of the pump. For a volume test, the pump should deliver AT LEAST a quart in a minute or less, at slow idle.
According to my old '70 book, the fuel pump should deliver 5-7PSI, but just about anything above 3 1/2 PSI should be OK.
Where are you, Rulito? I spose you use Kpa's for pressure?
NYCuda
04-28-2015 06:42 AM
demetri
07-12-2010 09:39 PM
Quick Reply: fuel starvation
