Mopar Forums (/forums/)
-   A-Body (https://moparforums.com/forums/f9/)
-   -   I messed up, need some advise (https://moparforums.com/forums/f9/i-messed-up-need-some-advise-14909/)
Sign Guy May 19, 2013 11:58 AM
Today I cleaned up my engine bay, cleaned with purple stuff cleaner and used a low pressure setting on the pressure washer to rinse everything down. Now of course the car will not start. Slant 6 in my 72 Scamp. I cleaned the distributor cap, it's dry. There is one white wire with a female spade connector on it, from the harness that runs along the valve cover on the passenger side. That wire is loose and I can not locate where it should connect. Could this be my problem? Any help would be appreciated.
62Furious May 20, 2013 05:04 AM
NOT SURE but the white wire may be the field wire for your altinator but that should not stop you from starting or runnig, just charging the battery
440roadrunner May 20, 2013 06:57 AM
If you got the ECU wet, and water on and around the heat sink, it may not work until dried out.
Have you checked for fire right at the coil wire?
Sign Guy May 20, 2013 02:58 PM
I don't see a place to plug the wire into the alternator, but I will check again.
It is getting some fire, because it will sputter like it's trying to start, I'm sure I got the ECU and heat sink wet, that may be the problem.
pro-tech May 21, 2013 01:09 PM
WD40 displaces water spray the cap and wires with it. Check inside the cap for moisture use compressed air and blow out any moisture. Also that white wire is for an electric choke which your car might not have. You can also use the WD40 insidethe cap sparingly. It works great.
moe7404 Jun 14, 2013 03:21 PM
if the cap has a vent hole. PLUG it with JB-weld
