Mopar Forums (/forums/)
-   A-Body (https://moparforums.com/forums/f9/)
-   -   Manual Disc to Power Disc (https://moparforums.com/forums/f9/manual-disc-power-disc-1888/)
Rbaisch Nov 29, 2008 07:55 PM
Hi, new to the forum. I have a 76 duster with manual disc brakes. Does anyone know what you have to do to make them power? Is it as simple as adding a power booster? Any info is appreciated, thanks
67 GTX Nov 29, 2008 08:58 PM
Welcome to the forum
not sure about power brakes, but i am sure someone on here can help you
78D200 Nov 30, 2008 03:05 AM
Welcome to the forum.
You will need a power booster, master cylinder and posibly a different brake pedal set up. The lines and everything ense should be the same. Plus a vacuum port from the intake.
challenger Nov 30, 2008 09:14 AM
i think you will also need a different pro valve and the brake pedal you might just have to change out the rod ..... is that correct 78 ?
78D200 Dec 1, 2008 02:17 AM
proportioning valve might have to get changed, i'd do it though just to be on the safe side.
