Mopar Forums (/forums/)
-   A-Body (https://moparforums.com/forums/f9/)
-   -   Orange ECU box with MSD Blaster 2 bad? (https://moparforums.com/forums/f9/orange-ecu-box-msd-blaster-2-bad-3156/)
dsmtuned May 27, 2009 09:11 PM
Hi,
For now I have the Mopar Performance orange ECU/electronic ignition.
I've heard that you can't use the MSD Blaster Coils with Mopar Performance electronic ignitions. True, false?
If so, which coil should I use for a street driven 440 magnum?
Thanks for the help.
-Craig
78D200 May 28, 2009 05:36 AM
I had an orange box in my 78 D200 with a MSD Blaster 2 coil and never had any problems. I also ran champion plugs and 8mm wires.
Crazy4Carz.Com May 28, 2009 08:18 AM
Agreed, just don't forget the ballast resistor.
dsmtuned May 28, 2009 12:59 PM
Which ballast do you suggest?
I had the 1 ohm that came with the coil and that one fried.
The car just stumbles with the .25ohm ballast that came with the electronic ignition kit.
-Craig
78D200 May 29, 2009 03:53 AM
http://store.summitracing.com/partde...0&autoview=sku
This is the one that I got from Summit Racing. It has a .700 Ohm resistor.
1 Bad Mirada Jun 2, 2009 08:58 PM
ive also heard that you cant run certain MSD parts with certain "stockish" parts..but i dont know of anyone who has actually had a problem with the combo.
78D200 Jun 3, 2009 01:51 AM
You mean like a controller? I have an MSD 5900 ignition box and blaster two coil that I am thinking about installing in my Valaint with a slant 6.
1 Bad Mirada Jun 3, 2009 06:33 AM
maybe it was with the magnum rams...if you used the MSD box you had to also use a certain MSD coil or it was causing computer issues or something...
78D200 Jun 3, 2009 07:06 AM
I have run MSD coils on my 2000 and 2001 Dakota's with 3.9L motors and had a friend run on on his 5.2L in a 98 Ram. never had an issue, of course we were also running 8mm wire. I'm not sure if running stock 6mm-7mm wires would have that much effect on it.
It could be wiring in an ignition box on a magnum motor though.
