Mopar Forums (/forums/)
-   A-Body (https://moparforums.com/forums/f9/)
-   -   power steering problem (https://moparforums.com/forums/f9/power-steering-problem-3059/)
allenw May 15, 2009 03:56 PM
I have a 76 dart swinger and i played with the steering column and the power steering box. I bolted everything back together and now the steering pushes all the way to the left by itself and i can not move the steering wheel. Anyone have any advice? Thanks
richinny May 15, 2009 06:24 PM
that return hose fitting on top slides. when off center it will push the steering to one side. with the fitting properly centered, the front wheels off the ground, the wheels should not turn when the engine is started.
Polaradude May 16, 2009 02:33 AM
X2
