Mopar Forums (/forums/)
-   A-Body (https://moparforums.com/forums/f9/)
-   -   Slant six engine paint? (https://moparforums.com/forums/f9/slant-six-engine-paint-7535/)
1966DartConvertible Sep 22, 2010 07:29 PM
Hi there
Couple of questions:
1. What is the paint code for the red-orangy 170ci engine paint and where to get/order?
2. Would you recommend an electric fuel pump or stay with the original mech pump? The engine is stock standard 170ci and is currently using "Mitsubishi" electric tick-tick fuel pump (the mech pump is not working).
Thanx for all the help guys.
Cheers
Syed
78D200 Sep 23, 2010 02:49 AM
As for the paint code, I can not help you out there.
For the fuel pump, you should run a mechanical. You can run an electric pump but need to run an adjustable regulator between it and the carb.
Polaradude Sep 23, 2010 02:57 AM
Mopar Part # P4349218 Red
67 GTX Sep 23, 2010 03:36 PM
keep a mechanical pump
i am pretty sure new ones are available
1966DartConvertible Sep 23, 2010 07:19 PM
Got this reply from Dupli-color:
"Thank you for your inquiry. Unfortunately we do not have any
distribution
of our products outside of North America. I apologize I could not help
you
with this request.
Regards,
Jared
Dupli-Color"
Hmm...
chlngr1970 Sep 23, 2010 10:24 PM
what would the legality of someone buying it for you here in the US and shipping it to you?
j
1966DartConvertible Sep 25, 2010 09:12 PM
j
I believed its the same as in the US of A... cant ship the aerosol by air... I guess the only way is to find a paint-chip of the DE1632 sample and ship THAT chip here...
blue 68 gts Sep 25, 2010 09:49 PM
Well.......
I know this may not help, because your motor goes red, not orange. But I painted my motor CHEVY orange. :D
Alot easier to come by + i find it looks better.
I suggest finding a some what dark red, like CHEVY red?
johnthegoalie Sep 27, 2010 12:59 AM
mine's blue :)
mechanical pump - the stock unit is good enough to feed a 500cfm 4bbl. they are uber cheap too - like 20 bucks
Salty Dec 11, 2010 03:41 PM
pumps.....
Speaking of pumps....
My 67 dart (/6, 170) has an electric pump, added by previous owner. Thing is really loud at times, rattling thru the entire frame. I just today discovered a pinhole leak in the fuel line from pump to filter, so I'm gonna replace the whole line cause it's rusty and crusty. While i'm it, i was debating replacing the pump with a quieter one. But since 67's didn't come with mechanical ones, I don't know what type or size to get. Any recommendations on a quiet pump that would work for the slant 6? Or would it make more sense to just go back to a mechanical?
And last question, can i replace the steel line from pump to filter with hose, or should I stick with steel?
Thanks in advance
sd
67 GTX Dec 11, 2010 07:54 PM
Thanks in advance
sd
i think 67 /6's had mechanical pumps
Salty Dec 11, 2010 09:52 PM
ooops, that was a typo....meant to say 67's didn't come with electric.....they only came with mechanical.....
so, just looking for a recommendation for a quieter electric or is it smarter to just go back to mechanical.....
67 GTX Dec 12, 2010 07:27 AM
the original carter fuel pump should be good for you
