Trying to identify engine: 64 Valiant
Hi
I just got this car a week ago and I am completely new to Valiants, Plymouth, Mopar....anything non VW actually.
I'm trying to find out what motor is in the car. I looked where a few other places said my ID should be, but nothing. I did find a few other numbers stamped in various places though and I was hoping someone may be able to help me identify or point me to a reliable source where I can identify.
here's what I know.
64 Valiant, 2 door, slant 6.
Facing the engine.
Lower right side on the block the number 2463230-9 is stamped.
On the plate on the cowling(?) By where the battery sits it says:
Number - 0514 3493
Bdy - 111
TRM - L1R (that ones hard to read)
Pnt - WWP (also hard to read)
under the valve cover I found the number - 2206086-1 with a large AA00 stamped.
The carb is a single barrel Carter.
Is there somewhere else I should look?
Thanks for your help.
-lemorris
here's what I know.
Facing the engine.
Number - 0514 3493
Bdy - 111
-lemorris
Maybe not the answer but some good "old" information.
http://www.slantsix.org/articles/Sla...g%20Manual.pdf
This looks like the low deck 170 answer.
http://www.slantsix.org/articles/dut...ant-blocks.htm
Casting# CID Year
2463230 170 1965
Can't find anything on the head #2206086
but the 2206 is definitely a 62-65 casting number, the closest casting I can find is Casting 2206035 Engine CID 170/225 Year 1962-65 Intake 1.62 Exhaust 1.36
Depending on the build date, it might be a 65 casting, or not original to the car.
Hope this helps some.
2463230 170 1965
heminate
08-10-2015 08:04 AM
Daytona45
03-16-2009 09:14 AM
