valve cover question
i just got my engine rebuilt not long ago and i want to know if i need to have air vent on both sides or can i have 2 on one side and one on the other, sorry if im not clear i dont know what there called
You should have a port opening for a PCV valve on the right (passenger side) valve cover connected to manifold vacuum, large port at the base of carb. Left side valve cover there should be a breather, either incorperated in with the oil fill cap or on its own either way these two have to be on opposite valve covers to properly scavage the blow by and reburn it.
Yep. Sweepers got it right.
Pass side has the PCV to the back of the carb And the driver side can be open or have a breather. Whatever works. |
sweeper -
OK, I'll bite, why the PVC on the passenger side? I've run my PVC valve on the driver's side and the breather on the passenger side, since I started out, and pretty much so did everyone else. Archer |
Originally Posted by Archer
(Post 47256)
sweeper -
OK, I'll bite, why the PVC on the passenger side? I've run my PVC valve on the driver's side and the breather on the passenger side, since I started out, and pretty much so did everyone else. Archer They came from the factory with the PCV on the pass side, and the breather on the driver side |
blue -
OK, but the crank case is effectively a closed system, and therefore blow-by can be sucked out of either side and the breather can vent from either side, so why does the PVC "have to" be on the pass side? BTW, you can make a case for the PVC and breather not being on the same side (valve cover). Frankly, IMHO it just looks better on the driver's side ;) Seriously, not trying to be a smart@$$, just want to know if there's a reason for doing something a certain way. Archer |
They can go on either side, I just like making my stuff look "factory". Makes my ride look more "sleeper" status.
Like my painted Aluminum intake and painted valve covers that have the brackets on them to hold the spark plug wires. |
(Post 47256)
sweeper -
blue -
Now we're talking the same language, cool! With this stuff, doing something for a certain look, is a perfectly valid reason in my book. Doubt anybody is going to believe that thing is stock, though ... :D Sweeper - Just wanted to make sure I wasn't missing something, been known to happen - more than once ... Archer |
| All times are GMT -7. The time now is 06:27 AM. |
