Mopar Forums (/forums/)
-   A-Body (https://moparforums.com/forums/f9/)
-   -   wheels and tires. (https://moparforums.com/forums/f9/wheels-tires-4940/)
thedusterridesagain Dec 20, 2009 10:19 PM
wheels and tires.
ok so 74 duster with 8 3/4 rear. will a 275 tire work on the back with stock backspacing. im thinkin a 275/60/15. i dont believe there will be clearence issues cause i have a 255 on it now with a decent amount of room but would just like to know. thanks.
3forty Dec 21, 2009 05:08 AM
What 8 3/4 do you have,A body?,B body?, what rear brakes?, small or large bolt pattern,all this info is important on using 275/60-15 on the rear.
thedusterridesagain Dec 21, 2009 02:21 PM
its an a body 8 3/4 . 489 case 3.55 gears. ssbc rear discs. smallest rim that will fit with the kit is a 14 so im good there. also its the large bolt pattern 5x4.5.
3forty Dec 21, 2009 03:38 PM
[quote=thedusterridesagain;34769]its an a body 8 3/4 . 489 case 3.55 gears. ssbc rear discs. smallest rim that will fit with the kit is a 14 so im good there. also its the large bolt pattern 5x4.5.[/quo
Should be no problems to run a set of 15x8 rims with 4 1/2 inch backspace and 275/60-15 tires. Thats what i ran on my '71 duster with big bolt axles and the large 10 inch brakes,had 1/2 inch clearance at least from sidewall to leaf spring. I have since moved up to 10 inch rims with 275/60-15 tires,tight fit.
thedusterridesagain Dec 21, 2009 04:04 PM
thanks alot.
