406 MAGNUM (Small block) CRATE ENGINE 435 HORSEPOWER
Paid $9800+ shipping and is brand new!
Open to cash offers. NO LOWBALLERS!! This 4.00" stroker engine generates a whopping 435 horsepower and 470 ft.-lbs. of torque, and will quickly make believers out of everyone. It features big valve Magnum R/T cylinder heads and stainless steel valves. Drop one in and let er rip. For maximum performance, Mopar recommends the use of a 750 cfm Holley carburetor (P4349228) and 1-7/8" exhaust headers. Specifications: Thermocycled Block Is Bored to +0.020" Oversize 4.020" Bore/4.00" Stroke 9.0:1 Compression Ratio Big Valve Magnum R/T Cylinder Heads Distinctive Mopar Cast Aluminum Valve Covers 2.02" Intake and 1.625" Exhaust Valves Heavy-Duty Valve Springs Hydraulic Roller Camshaft 288ฐ/292ฐ Advertised Duration (230ฐ/234ฐ Duration @ .050") 0.501"/0.513" Lift Single Plane, M1ฎ 4-bbl Aluminum Intake Manifold (Includes Bosses for MPI Conversion; Taller than Stock Check Hood Clearance) Double Roller Timing Chain and Sprockets 8-quart Center Sump Street/Strip Oil Pan Mopar Electronic Ignition Kit with Distributor Heavy-Duty Engine Stand and Engine Crate Does Not Include Accessory Brackets Not for Use with A/C or for Factory MPI Installations High Volume Oil Pump Externally Balanced to Stock (Production) 19932003 360 Magnum Engine; |
I'll give you $20 if you cover shipping. lol
Whom built it?
| All times are GMT -7. The time now is 04:56 AM. |
