440 HP Exhaust Manifolds
Old 10-22-2014 | 01:31 PM
brian7786's Avatar
I was wondering if HP exhaust manifolds were available for a 1971 Chrysler New Yorker 440 engine.
If so, does anyone know what the manifold numbers are.
Also, will the HP manifolds fit other years..
Old 10-22-2014 | 07:18 PM
moe7404's Avatar
i only have a little info. i do know that the 1969 300 could have had a HP 440. and i will GUESS the 71 300 will be the same body, just a GUESS. and the AVS carb often times has a small flat spot off idle. easy to fix by drilling idle jet by .001" but it does have to be done right.
Old 10-22-2014 | 09:22 PM
moparted's Avatar
yes there are 71 c hp manifolds.
http://www.accurateltd.com/C-Body-Ba...LP-_p_353.html
brian7786 (10-23-2014)
Old 10-23-2014 | 09:02 AM
moe7404's Avatar
this may not be important. most lettered 300s early 60s, had HP ext manifold. but the 1965 300 L 413, 360 horses, did NOT. it had the same ext as a new yorker, 340 horses, and the 65 did NOT have the long ram intake. it would NOT clear the inner fender. the HP 413 that year was the same color as a new yourker mild engine , turquoise color.
Old 10-23-2014 | 02:46 PM
brian7786's Avatar
I forgot to mention the engine has been rebuilt and is in a 1967 Satellite so under hood clearances are different from the 71 Chrysler. I am guessing the HP exhaust manifolds will fit under the hood of the Satellite. Is this correct?
Also, any idea where I can buy manifolds at a reasonable price? Thanks
Old 10-23-2014 | 10:53 PM
moparted's Avatar
u need b body manifolds
Old 12-06-2014 | 08:45 PM
cbody70's Avatar
http://www.ttiexhaust.com/Category-C...st/MFDback.htm
FYI here is another resource...
shawnp67b
03-07-2024 03:33 PM
rockdog2112
12-04-2014 11:06 PM
castillo70
13
06-03-2014 05:25 PM
440-4x4
12-10-2009 10:43 AM
J Dog
06-26-2008 08:10 AM
