72 318 block with 340 Stroker Kit.
I've got a 72 Plymouth 318 block that has been cleaned and bored 30 over. The deck has been milled as well. New freeze plugs and cam bearings have been installed. The build was designed by Hughes engines rated at 400 HP.
I have new in box, cast LA "X" heads with stainless valves. The stroker kits includes the following. All parts are new in boxes. SCAT- cast Iron crankshaft. $2500.00 SCAT -pistons and rods. Ring set and rod bearings included. CRANE- cam New lifters New double roller gear set and chain New oil pump New engine hoist and stand I also have some misc parts ie... oil pan, alternator bracket, etc. You can text/call me at 614-855-8216 |
