727 Transmission & GV Overdrive
SOLD -
727 Torque Flight from Turbo Action Including valve body without trans brake. -2,400 Stall Torque Converter -Flex Plate -Drive Shaft (set up for 67 Cuda) -Hurst Quarter Stick Shifter #130 055 with Pistol Grip Handle & Built In Switch for Trans Brake or Line Lock #316 2009 With Cable -Gear Vendors Overdrive Unit Model #3A0727 In process of reworking my 67 Cuda resto mod with a more modern transmission set-up. All parts were new and used for only for street cruising mated to a 6.1 Hemi. Approximately 9K miles since installed. $1250 takes it all. Pick-up in Cincinnati Ohio. |
Wish I had the $$$$!
