MoPar 318 Poly Wide Block 4 Barrel Intake Manifold Carb & Snorkel
Greetings!
Up for sale is a very rare MoPar Factory 4bbl intake for 1957-1966 318 poly head wide block motor. Much better than the only other option, the Weiand, as this factory option retains all the correct mounting for stock throttle set up and heater/radiator hose fittings! Casting # 1859229 Intake was blasted and powder coated, carb completely rebuilt including new secondary. Never used since being rebuilt. Includes a new set of unused intake gaskets new in the box as well as a factory 4bbl air cleaner. Air cleaner is in need of restoration. The carb is early 60's, indicated by the choke pull off is piston, not diaphragm. The power piston cover is flat meaning the rod, two steps, and jet are the short version. (Thanks @moe7404 for the carb info!) Must be split into 3 boxes for shipping, not really interested in splitting up set. Purchased this for 66 Blevedere II that I wound up selling prior to install. Looking for 800 for the setup. Shipping was about 60 from the midwest for the mani. I will ship the other two boxes for free, if in Continental USofA. If you want to calculate for your location, 53 lbs in a 18x16x12 box If interested, PM me and I'll forward by contact info http://i116.photobucket.com/albums/o...psecede906.jpg http://i116.photobucket.com/albums/o...ps9f5be306.jpg http://i116.photobucket.com/albums/o...ps4e77387a.jpg http://i116.photobucket.com/albums/o...ps57deb9c3.jpghttp://i116.photobucket.com/albums/o...ps7e3e277e.jpg |
SOLD
| All times are GMT -7. The time now is 11:06 PM. |
