WebElectric Sequential Turn Signals Kit for Challenger
Old Aug 8, 2012 | 10:58 PM
JETBLU's Avatar
SOLD!
Brand New, Never Installed, WebElectric Sequential Turn Signals Kit.
"Plug-N-Play" Installation Smart-Sequence Technology Auto-Adjust Circuitry No Fixture Modification Required!
The STS-4CHSS Sequential Turn Signal kit will convert the taillights on your 2008+ Dodge Challenger into Sequential Turn Signals.
This is a true Plug-N-Play kit. You do not have to break off any rivets. There is no need to go into the fuse box to make any connections. Return to stock at any time without any evidence of ever being there! The kit contains pre-wired, plug-in harnesses that install with no wire cutting or splicing of any kind. (Note: 2011 and newer cars need one ground wire splice) *
With Smart-Sequence technology, your tail lights sequence ONLY when a signal is on. When you hit the brakes, all lamps come on together.
Plus, these harnesses feature sophisticated electronics that automatically adjust the sequencing speed to match the turn signal flasher in your car. While other products offer you fixed timing or complicated manual adjustments, Web Electric electronics sense your car's flasher speed and adjust the sequence timing for you.
$125 Shipped.
lifted150
Apr 8, 2022 07:09 PM
JP67
Aug 17, 2012 07:34 PM
JP67
May 10, 2012 03:42 PM
67Polara
Jun 8, 2009 05:53 PM
johnnyc
Mar 4, 2008 06:13 AM
