8.25 axle shafts
Old Aug 16, 2015 | 03:31 PM
randy4662's Avatar
8.25 axle shafts
Hi,
I have a 8.25 axle with sure grip. My right side axle shaft is pitted. I installed a repair bearing, but it didnt help. the pitting is on the whole surface. Needless to say, it is roaring real bad. My problem is I cannot find a new axle the right length. I have the axle out, and no matter how many times i measure it, it is 28 1/2 inches long overall. 28 inches long from the outer side of the flange, to the c-clip end. the shortest replacement axle i can find is 29 3/4 inches long. i have searched by casting number, and still couldnt find a replacement.
can the axle be remachined? ground down and a larger bearing installed? has anyone else ever had this problem?
Old Aug 16, 2015 | 05:16 PM
Magoo's Avatar
Thumbs up Go to a 8-3/4 Rear
Switch to a 8-3/4 rear, if you can find one. - Depending on your area, that may be difficult.
Old Aug 16, 2015 | 08:21 PM
randy4662's Avatar
I have one! Its a peg leg. What parts do i need to make it a sure grip? Do i have to change the whole chunk or can i pull out the carrier, and just replace that? will the old axle shafts still work?
Old Aug 16, 2015 | 09:32 PM
Magoo's Avatar
You need the entire housing, axles, carrier with sure grip etc. -- Not sure about backing plates and brakes, but probably those too. -- It's an easy switch, but unless you can find one for a reasonable price, it will get expensive. -- This may not be for you to do. -- Unless you are setting up for major HP, you don't need it.
Old Aug 17, 2015 | 08:43 PM
Check to see if they make a repair sleeve, Their is also a repair that moves the bearing to a different part of the Axel ??
Old Aug 22, 2015 | 05:06 PM
68plymouth383's Avatar
I have a good used pair of 8.25 axles. I'll measures them.
Old Aug 27, 2015 | 05:29 AM
randy4662's Avatar
Did you measure them?
jeff1010
Aug 8, 2011 05:42 PM
Mar 7, 2011 05:00 PM
DandyD
Aug 17, 2010 10:14 PM
Commando
Apr 5, 2009 03:52 PM
Jonah Hex
Oct 17, 2007 04:14 PM
