Mopar Forums (/forums/)
-   MoparForums Rules, News, Comments and Questions (https://moparforums.com/forums/f92/)
-   -   HELP! (https://moparforums.com/forums/f92/help-24458/)
Moparbella08 Feb 20, 2022 07:19 PM
HELP!
I have 2020 Dodge Charger with about 13,000 miles on it. I was pulling out of a store parking lot mind you cars was already running and driving. As I’m pulling out of the parking lot out to the main Road (It was dark out) I noticed my dash light up! when I looked down my gauges were moving and all lights on the dashboard were marking as if my car was just Being turn on! Music was still playing and I accelerated a little harder to see if maybe my car with failing or turning off. It wasn’t. I was startled for the rest of the way home about 15-20 mins away. Possible electrical problem.
Iowan Feb 20, 2022 09:40 PM
I would verify that you have a good connection on both ends of the battery cable's. A bad ground will make your dash go crazy...
Archer Feb 21, 2022 04:26 AM
M -
What Iowan said, or you could have blown a sensor. I had something like that happen to my Challenger a few years back.
Checking for engine codes might tell you what the deal is..
RacerHog Feb 21, 2022 07:34 AM
My suggestion is to take it back to the dealer. Should still be under warranty (3 years or 36,000 mile).. Check with them first....
If not? Then I agree with the others... Check the Battery Connections as well as testing the Alternator and Battery.
