engine swap
Old 07-28-2018, 12:07 PM
radical fred's Avatar
engine swap
I have a 1976 dart sport with a 318 4 speed. I have found a 440 to put in the car, other than motor mounts, rad and torsion bar what else needs to be changed? what bellehouse will I need to connect the 440 to the 4 speed? will the drive shaft need to be shortened?
Old 07-28-2018, 03:08 PM
Most likely you have the aluminum case 4 speed (3 speed with 4 an over drive). I don't think it will last long behind a 440. But that depends on your driving. possbly a rear swap in the future from your current 8 1/4. Personally I would build a stroker small block
Old 07-28-2018, 03:40 PM
http://www.engine-swaps.com/Pages/Pr...3UP.html#head2
Old 07-28-2018, 03:46 PM
Wink
A stroker kit for your 318 would be simpler but a A body 4 speed 74 or earlier is needed and you will also need a heavier rear axle, 83/4 mopar or 8.8 Ford. As far as the 440 goes you need to make sure the crankshaft is drilled for a pilot bearing for the input shaft on the 4 speed, so were not drilled.
Old 07-28-2018, 03:51 PM
thanks for the advice, I just priced a stroker kit that takes a 318 and makes it into a 390. think this is the way to go if the machine shop cost is not huge.
Old 07-29-2018, 08:46 AM
I agree, it's been done many times, you can search builds, find the one you like and copy it for proven results. Lots of power in a small package.
Blue92w150
08-08-2020 11:06 AM
Gene75D100
06-29-2018 06:11 PM
cbrewer
12-08-2015 09:04 AM
Boivin913
10-02-2015 02:15 PM
josehf34
11-14-2012 06:39 AM
Quick Reply: engine swap
