Mopar Forums (/forums/)
-   Member Builds (https://moparforums.com/forums/f95/)
-   -   Coolant leak (https://moparforums.com/forums/f95/coolant-leak-22373/)
dwruble23 May 31, 2019 10:53 AM
Coolant leak
I am having a small leakage of green coolant. By small, I mean fairly slow, its not spewing out. However, I cant seem to find the location for the leak. I am going to go to autozone and get the radiator pressure gauge/pump to see how fast the pressure drops. Any ideas on how to find the leakage spot and what else could potentially be?
Thanks
Iowan May 31, 2019 10:57 AM
What vehicle/motor do you have? Is this your 318 Duster?
dwruble23 May 31, 2019 10:58 AM
I have a 1973 Duster with a 318 motor
Iowan May 31, 2019 11:03 AM
First thing I'd look at would be the water pump and see if its seeping out of the bottom behind the pulley.
dwruble23 May 31, 2019 11:08 AM
Okay I will check that tonight after work. That would mean replacing the water pump wouldnt it?
Iowan May 31, 2019 11:20 AM
After that look at the thermostat housing, intake manifold at the heads, radiator hoses and radiator and heater core and hoses. It is possible that the heads are cracked and you might see water leaking from the castings or you have a head gasket issue. But this is a start on places to check for water. If it's the water pump you will need to replace it and it's not a bad job at all. If radiator or heater core cooling system sealer can work hoses need replacement.
Intake manifold gaskets leak over time as do thermostat gaskets so you will need to replace them at some point especially if a previous owner with little experience had gotten into the motor for any reason.
Good luck with your search
Iowan May 31, 2019 11:24 AM
If you can't find a leak try a bottle of Copper seal in the radiator, Copper or Silver.
https://www.zoro.com/bars-leaks-radi...QaAr_dEALw_wcB
RacerHog May 31, 2019 11:27 AM
Just to add to the list... Freeze plugs?
????? Coming from the Front, Side's, Back?
Put a piece of cardboard down to locate the area also, if needed????
RacerHog May 31, 2019 11:28 AM
And or shoot us some photos... to help you... :)
Iowan May 31, 2019 11:42 AM
Yep rusty freezplugs can get you and can be a pain to fix in the car.
