Mopar Forums (/forums/)
-   Member Builds (https://moparforums.com/forums/f95/)
-   -   HELP (https://moparforums.com/forums/f95/help-25655/)
Newbeemoparfan May 12, 2025 07:56 AM
HELP
Hi, I just rebuilt this motor in my 99 Dodge ram 5.2 L. It won’t get any fire. I don’t have no fire. I got fuel for no fire not the cold pack. It’s not. I don’t know what it is honestly ideas please I’m desperate. I got like eight grand in this truck and want to drive it
Kuvasz101 May 12, 2025 09:15 AM
I guess the basics first. We're assuming the engine is turning but you have no ignition.
Newbeemoparfan May 12, 2025 11:51 AM
Yep that’s what’s going on everything is new
turns over good everything is good. I’m getting fuel, but I’ve got no spark i checked everything I think. But I’ve got to be missing something.
Kuvasz101 May 12, 2025 04:35 PM
To eliminate a wiring issue, run a wire with alligator clips from the positive side of the battery to the positive on the coil. That bypasses ignition and related wiring. Try cranking it and check for spark. If you have it, you have a power issue that needs to be traced.
Newbeemoparfan May 14, 2025 04:25 AM
I’ll do that and see what I get
