1980 dodge w150 head
I have a 1980 dodge w150 with the la 5.9 360 in it i took off my heads and noticed theres a hole in them shaped like an upside down u with a rectangle in the middle of it. It was completely clogged full of junk. I cant seem to figure out where it goes or what its supposed to do. Any help would be appreciated
Thanks, Tad http://www.rockauto.com/catalog/more...nid=527&jpid=0If you go threw the pictures on the link it shows the hole im talking about. |
Originally Posted by tadmorris95
(Post 130808)
(Post 130809)
That would be the exhaust crossover, used for heating the base of the carb.
welcome to the forum, performance manifolds don't. it's just fine.
Some gasket kits come with "block off " plates for the heat passages, or you can make your own from some thin tin(soup can).
It sent hot air to the EGR system / engine warm up.. Always got clogged with carbon buildup Fine to leave it open or you can block it closed
