1989 dodge w100 transmission
I am restoring my 1989 dodge W100 power ram. i was wondering how i can tell if the transmission is a 727 torqueflite or if it is a 904 torqueflite
okay thank you. now would you know why the transmission would not fully engage until 3000-4000 rpm
Is it low on fluid?
(Post 148588)
Is it low on fluid?
i have come across that once. but sadly it is not the problem this time
Mite check the band adjustment.... Also was the fluid burned up that us in it? Also Check the throttle valve linkage/cable adjustment.
Just my thoughts.. |
I had a 904 once that the finger was plugged and it would not move when cold.
(Post 148609)
Yes but your bigger.🙂
:laugh:
