Mopar Forums (/forums/)
-   72-93 Dodge Trucks (https://moparforums.com/forums/f96/)
-   -   440 distributor question (https://moparforums.com/forums/f96/440-distributor-question-6470/)
2002ram440 Jun 7, 2010 03:34 PM
i have a 440 from a 78 motorhome with mild cam running 10.5:1 comp. i can not get the advance timing right. i was told by a Mopar guy that i need to be 28 to 32 degrees total advance but i am getting about 45. i have chnaged the pick up coil and the vacuum advance. i have changed the springs adn still too much. any ideas?
Barfly Jun 7, 2010 04:08 PM
Points or electronic ignition?
2002ram440 Jun 7, 2010 04:14 PM
electronic
Barfly Jun 7, 2010 04:33 PM
I just learned this recently myself, and more or less was warned against trying the adjustment. But on distributors with electronic ignition there is an adjustment screw inside the vacuum advance unit. You pull the hose off and insert a 3/32" allan wrench to adjust the amount of advance the diaphragm gives.
One Second I will try and find the reference........
Here it is see the Electronic Ignition part of the article.
And remember the guys that responded to my question kinda warned against fiddling
with this.
Joe.
