78 dodge w150 steering column
I have a lot of slop in my steering. I am having a hard time locating a new steering column. Will a 2wd column work. Are the columns year specific.
Hello
Are you sure it's the column and not the u-joint, rag joint or steering gear? What condition is the rest of the front-end in? I have no idea about the capability between 2wd and 4wd parts but, I may know where you can get the parts you need. I did business with Joe Leonard over at Mopar Truck Parts when I was converting my truck over to power steering and was having trouble locating the parts needed. https://www.mopartruckparts.com/contact.html If it turns out your steering gear is at fault, I've heard it's best to have it rebuilt rather than replacing it with a reman unit. And the place I've heard to have it done is called RedHead Steering Gears but, I've yet to do business with them. I hope you find this helpful. |
Originally Posted by dodgem880
(Post 141891)
Hello
Originally Posted by Meangreen
(Post 141893)
thanks. Still diagnosing the problem. Redhead is actually a few miles from me. Ill get in touch with joe though probably
