82 D150 Motorized to Hand Crank Windows
Old May 27, 2024 | 10:20 AM
DaneSlayer's Avatar
I have a 82 D150 and it currently has motorized windows that have bad motors, would rather have hand crank windows. Are the motor assemblies able to be swapped out with a hand crank?
Old May 27, 2024 | 10:40 AM
dodgem880's Avatar
The window regulators are different between Hand and Electric power windows.
According to LMCTruck anyway...
Old Jun 13, 2024 | 08:45 AM
Abcdefghii's Avatar
They are indeed difference, I have crank windows and needed to replace both regulators..... I could find electric ones all day long, finding manual ones.... yeah, that was a treasure hunt that eventually involved calling a dozen or more junk yards until I found a pair.
If making the swap to manual, you would also need a pair of new door panels I would think, I can't picture where the holes are for the electric switches, but would be surprised if they match the hole position and shape of the manual panels.
Old Jun 13, 2024 | 11:03 AM
Try running the info in this system.....Also Check Dorman, call the support staff.... Good Luck....
https://www.car-part.com/
Old Jun 13, 2024 | 04:14 PM
dodgem880's Avatar
I've used Dorman manual regulators. They seem to work find however they do have a flaw I would watch out for. The adjuster for setting the lowering limit uses an eccentric cam pressed onto a shaft.... this cam can slip (on the shaft) allowing the regulator to lower too far and fall off the tracks/hangers. I used my mig welder to fix this issue.
Old Jun 13, 2024 | 06:20 PM
Great info M880 !!!!!!
Billybjr
Aug 23, 2023 01:36 PM
rrgaines
Jul 19, 2022 09:13 AM
Jbutler996
May 26, 2022 10:05 PM
Tdander
Apr 25, 2021 03:33 AM
Harolds
Oct 20, 2020 06:02 PM
