AC to non-AC and now alternator doesn’t line up
Old Sep 24, 2022 | 08:52 PM
nballen_W100's Avatar
Newby to this forum and these trucks, so bare with me.
I’m in the process of rebuilding my truck (comprised of 75 frame and suspension and 78 engine and body) and have hit a snag.
When reinstalling the accessories onto my 318, the alternator seems to sit too far back now (nearly pressing up against the block), the adjustment bolt doesn’t line up anymore and I can’t figure out how to fix it.
Originally it was an AC truck, but since most of the parts are missing I am doing away with the compressor and such brackets and picked up a non-AC alt bracket. Can I use the same alternator or do I need to pick up a 1v pulley alternator?
I appreciate any wisdom you can give me.
Old Sep 25, 2022 | 06:36 AM
Archer's Avatar
n -
I did a lot of those "conversions" back in the day. You might be able to find non-AC brackets, or just use longer bolts with spacers.
Archer.
Old Sep 25, 2022 | 10:28 AM
yeah or if you have a grinder and a drill just make your own mounting arms.
Old Oct 1, 2022 | 03:50 PM
Solution
Turned out I needed to use a different lower mount as well, position the alt to straddle the upper bracket and create spacers (and linger bolt) to solidify the upper mounting position.
2 spacers needed
1v pulley alt
mahd
Apr 21, 2018 09:05 AM
josehf34
Jan 5, 2016 01:36 AM
coronet69
Nov 19, 2013 04:04 PM
98 SNAKE EATER
Mar 23, 2013 07:51 AM
roadrunnerrelic
Nov 7, 2008 06:56 PM
