ASD relay
1991 dodge d150 5.2 liter Truck won’t start unless you hold the contact points together manually, on the asd relay,But let go of closing of points manually engine stops. What energizes this ASD relay to stay on? Tired several new relays.
Find a wiring Schematic at (ALLDATA.COM) and check the relay power wire from the PCM...
| All times are GMT -7. The time now is 01:05 AM. |
