Air Conditioning System Replacement
I have a 1986 Dodge D150 pickup. The A/C does not work. The R12 refrigerant is either low or completely leaked out. The compressor clutch will engage when the low pressure valve is shorted. Nothing shows in the dryer sight glass. All of the A/C components appear to be original. Since I just bought the truck I don't know when the A/C last worked. Should I replace all of the A/C components (compressor, dryer, condenser, expansion valve) before I even try to recharge refrigerant with R134a? I'm afraid that I would just waste the cost of a recharge with the old components in place. Any advice would be appreciated. Thanks.
Put some guages on it to see if there is any presure left in the system. Then vacuum the system and recover anything thats left. At a minimum, I would replace the dryer and the o-rings on the lines. Inspect the lines for damage. Replenish the system and check for leaks.
I am having issue in air compressor & I am trying to decide whether to find air compressor replacement parts or just compressor replacement with new one. So I need agency for replacing my ac parts etc where does it get to me? Specially in California.
http://www.autoacforum.com/
You need to put it under a vacuum and see if it holds vacuum http://www.ackits.com/,, |
Originally Posted by TVLynn
(Post 109485)
| All times are GMT -7. The time now is 02:53 AM. |
