Axle swap questions
Old Oct 29, 2023 | 03:28 PM
Austin s's Avatar
Axle swap questions
So I have a 1982 dodge d150 short bed that's been going under a ton of modifications the last few years. It came stock with a 225 slant six and a A833 4 speed with over drive. My goal is to eventually have a really heavy half ton... I want a different rear axle without breaking the bank. The truck currently sits on top of 30 inch tires and a 8 1/4 rear axel that has 3.23 gears. I'm currently building a 318 atm and plan on putting it in soon. Keeping the transmission I have. I'm babbling, my question is what rear axle would work easily. Like could I put a jeep axle underneath? I live in Central michigan and for whatever reason I struggle finding parts in my area..
Old Oct 30, 2023 | 04:22 PM
Maybe find a B3500 1 ton to swap out..... Cheers
Old Oct 30, 2023 | 04:27 PM
Austin s's Avatar
So no jeep axle?
Old Oct 30, 2023 | 04:29 PM
I dont think they are wide enough? " From Backing plate to backing plate?
Old Oct 30, 2023 | 05:40 PM
I swapped an 8 3/4 axle from a 60s Dodge pickup into my 1977 D150, it came with a 3.55 gear but my 77 had the smaller 5 on 4 1/2” bolt pattern. For your application I would recommend a 9 1/4 from a newer pickup, early 2000s 3.55 gears and limited slips are common.
Old Oct 30, 2023 | 05:47 PM
Austin s's Avatar
That means welding
Old Oct 31, 2023 | 08:32 AM
Originally Posted by Austin s
That means welding
I believe it is a bolt in, both trucks are leaf spring setups.
Ohiokidde23!
Feb 19, 2023 06:13 AM
N2STC
Nov 20, 2022 11:37 PM
randy4662
Aug 27, 2015 05:29 AM
mopar318
Feb 13, 2013 10:35 PM
Jul 24, 2009 09:20 AM
