Carburetor with electric choke
Abcdefghii on this forum just went through putting an electric choke on his 1981 D150 318. I'm sure he could point out where he bought his.
I bought my electric choke kit from mikes carburetors.... Bolted up easily enough to the 2bbl Holley carb I have on there. It did need some slight tweaking to get it mounted where the choke closed fully, I had to add a spacer to raise the choke to slightly.
If you need the carb as well, I'd look for a Holley 2280, that's what I have and should bolt up simply.
This carb https://nationalcarburetors.com/Chrysler-1979-1980-318-52L-Holley-2280_p_2276.html
And this electric choke https://www.carburetor-parts.com/electric-thermostat-choke-cu1274
That's great, if you run into any problems feel free to reach out. As I mentioned, for me, the biggest piece was that the arm on the electric choke was slightly too short so I needed to add a spacer beneath it to raise it up about 1/8"
There's a bunch of info in the thread I have going here, a lot of dumb questions that I've had great help with.
