Computer code 052
Well,
My 1990 D-150 (318 Automatic, throttle body) was running so good. Today on the way home it started running rough again at a stop light. My engine check light came on. I got my scan tool out and it showed code 052 excessive lean. any idea's on what is causing this one? Thanks Gary |
Haynes manual give that code will turn up when signal from the O2 sensor isn't right. I will check that out tomorrow and go from there.
I'm Going to guess a wiring problem? Code 052? O2 is normally a Code 21??
But I think you need a DRB-II to reset the Emission Maintenance Reminder ... :) Rest of the tune up is good? Cap, plugs, rotor, plug wires, and so on. |
| All times are GMT -7. The time now is 03:38 AM. |
