Mopar Forums (/forums/)
-   72-93 Dodge Trucks (https://moparforums.com/forums/f96/)
-   -   door hinges like duct tape... (https://moparforums.com/forums/f96/door-hinges-like-duct-tape-5970/)
Hollonator Apr 20, 2010 06:26 PM
The lower door hinges on my 1979 Dodge W100 are terrible, wore slap out. And my luck for finding new ones for less than $80 a piece is bout the same luck I've had with the lottery, hence why I'm not willing to spend $80 on a door hinge...The lower hinge on the passengers side can just get a rebuild kit but I can't rebuild the lower driver's side cause it ain't even got all the parts! Any suggestions? Thanks.
Beerstop Jan 2, 2011 11:32 AM
junk yard
or mopar only out in michigan
67Polara Jan 4, 2011 12:33 AM
try taking them off another year ram ? might be cheaper...
78D200 Jan 4, 2011 02:31 AM
Only way around it (cheaply that is) is to buy a hinge off of a donar truck.
BuckNeccid Jan 4, 2011 02:47 AM
Pull the hinges, remove the pin, weld the hole up. Re-drill the hole the size needed and replace the pin with one out of any of the door hinge rebuild kits?
trivium Jul 2, 2011 05:22 PM
your not looking for the hinge, your looking for the hinge pins and bushings unless i misunderstood the problem, look on ebay and you will need two people to change them.
