Intake
I have a 91 Dodge w150 I swapped a 5.9 out of a 1986 Dodge ramcharger. The ramcharger had a quadrajet carb and I'm trying to put a Holley carb on the intake and need a adapter but I can't seem to find one anyone here know where I can find one
Kevin -
EBay has several of the spread bore to square carb adapters, starting around $12. But so does Summit and just about everybody else. Just do a google search on "square bore to spread bore adapter" Archer |
Originally Posted by Archer
(Post 151600)
Kevin -
Here's the best fix for your problem.
https://www.summitracing.com/parts/edl-2176/make/dodge |
Kevin -
Really? EBay https://www.ebay.com/i/333297234525?...CABEgINQfD_BwE Amazon Summit https://www.summitracing.com/parts/s...iABEgK7dvD_BwE Holley https://www.speedwaymotors.com/Holle...ge,142355.html Jegs https://www.jegs.com/p/JEGS/JEGS-Spr...78810/10002/-1 Edelbrock https://www.edelbrock.com/carb-adapt...bore-2696.html Not sure what's different about YOUR intake, but I ran a TQ on a Eddy square bore with the adapter on a small block for years. You just flip the adapter. Archer |
You have more time than I do Archer!
I still like my adapter better.......... |
I -
Yes, a better manifold is always a good idea, and I'd go that route as well, but it's $20 vs $300+ and 10 minutes vs a hour or so. Plus he gets that cool high rise effect... ...and the search took about 2 minutes :) I'm guessing he couldn't kind one because he was calling it by the wrong name. Archer |
What intake manifold is on the engine now?
| All times are GMT -7. The time now is 01:25 AM. |
