Ram 100 motor mounts
Please help, I have a 1988 Dodge Ram 100 that I removed a 3.9 and installed a 1970 318. Motor mounts are the problem. The v6 mounts are about 4 inches too far to the rear, is there a plate or mount system that bolts in from a v8 ram? Shcumacher does not make any...thanks
You should be able to remove a set from any V8 truck. I can't recall if they are fully welded or just riveted in though.
| All times are GMT -7. The time now is 02:20 AM. |
