Mopar Forums (/forums/)
-   72-93 Dodge Trucks (https://moparforums.com/forums/f96/)
-   -   Transmission dipstick? (https://moparforums.com/forums/f96/transmission-dipstick-24899/)
rusty dawg Jan 16, 2023 06:22 PM
Howdy,
Newbie here. I recently picked up a 1972 D100 truck with a 318 combined with a 3 speed (A-230) manual transmission. After searching on the web for a long time for where the heck the transmission dipstick is located, I decided to turn to this forum for some help. I've looked high and low to no avail.
As a side note, I did find a broken spring on the bottom of the trans that may have been the return spring for the slave cylinder, but I can't find a schematic to this transmission in hopes of buying a replacement spring. Not sure if what I found is just missing the hook portion or if it's half the length of the original spring.
Warm regards,
Roman
fivepoint Jan 16, 2023 06:55 PM
Rusty
The manual transmission does not have a dip stick. The oil level is checked by removing a plug on the side of the transmission. the oil level should be at the bottom of the plug hole. I'm not sure what spring you are trying to identify. Strongly suggest you find a manual to guide you through. Your local library may have a Chilton or Motors Manual for reference.
If these questions were meant to be a joke, then the answer is the dip stick is right behind to steering wheel.:dance:
rusty dawg Jan 17, 2023 12:54 PM
Originally Posted by fivepoint (Post 160630)
Rusty
They weren't meant to be a joke, but you are in essence correct in this instance. Thanks for the response, much appreciated.
