aw, crap - it's broken!
Old Nov 9, 2007 | 07:52 PM
I would think that this repair (by a novice) would be risky. If your welder friend is confident he can pull it off, I'd do it. The general method for "stopping" cracks is to drill holes at the ends and tapping in some threaded plugs.
Old Nov 18, 2007 | 10:50 AM
The thing you have to remember about repairing this as opposed to something like a transmission, is that this area is subjected to EXTREME changes in heat, because of exhaust heat. Also, aluminum becomes contaminated with whatever (exhaust deposits) that it's subjected to, making it difficult to clean. I'd be up for paying a pro.
I've played with this rod, and to use it, you REALLY need special goggles known as "cobalt blue" These are not cheap sunglasses sometimes called by that name. They are special lenses that used to be used for things line forging glass. The LET IN the high end blue and ultra-violet spectrum, and are the ONLY thing that will "cut through" the messy gaseaus cloud that surrounds your torch when using this aluminum rod. You can find these on eFray by searching for things like "glass blowing". If you search for "cobalt blue" by itself, you'll be inundated with junk glassware.
Here's a little more:
http://www.aws.org/cgi-bin/mwf/topic_show.pl?pid=17252
I believe these lenses were taken off the "official" market for safety. If you put them on either in sunlight or indoors in a shop lighted with flourescent lamps, you instantly believe you are in a room lighted with a "black light." Your fingernails glow, your white T shirt flares, and the sheet-rock walls are all, like, cool, what, man, eh?
However, they are magic when gas brazing aluminum
As I was about to give up, I found this:
http://www.amazon.com/gp/cdp/member-...stRecentReview
Evidently TM2000 lenses, though expensive, are the "new" cobalt blue replacements:
http://www.tinmantech.com/html/tm2000.php
scotty
Jan 14, 2012 03:21 PM
samuelcosmo76
Feb 27, 2010 10:57 AM
Crazy4Carz.Com
Feb 15, 2010 06:42 AM
Rosfrei
Sep 21, 2009 07:33 PM
nesparky
May 26, 2009 07:37 AM
