1970 charger RT found
Old Nov 13, 2007 | 05:46 PM
Why do you say "obviously a hemi?" It sounds like you haven't really looked at the car.
First thing to do is see if it's for sale!!!
So far as options, just LOOK!!! and see what's there--AC, etc, as well as two numbers--
The vehicle ID which of course is just like your Chivy, under the windshield on drivers side. This will tell you the year and engine
Also, under the hood is the "fender tag" which will give you other options and paint code.
So far as engines---who knows, someone might have put "something else" in the car. Chrysler engines are EASY to ID--much easier than Chivvys
318-340-360--distributor in rear, engine no. just under head on driver side on block, has CID encoded into no.
423-426(wedge)-440-has distributor in front, has small rectangular boss horizontal to ground at front of engine near distributor, and adjacent to metal strip which clamps the front of the valley cover. will have CID or part of CID stamped on that boss. If it's a stock single 4, it's a 375 hp 440, the six pack is obvious
Hemi's are obvious
383-400 does NOT have the little block mentioned for the above engines, other wise looks similar with front distributor
This car is old enough that "who knows" what someone swapped in the car?
Here's a pic of an "RB" (raised block) engine, with the 413-426-440 ID boss. It's the horizontal rectangle in the rusty area, closest to the drivers side, just above the water pump mount. Once again, only the long stroke engines have this. The old 361, and the 383-400's do NOT have this boss
This is why NOBODY can ever BS someone about 'having' a 426 or 440 when it's really one of the shorter stroke engines.
Also, because the SB's have the no. on the front of the block, you can't BS me about having a 340 when you really have a 318!!!
Old Nov 13, 2007 | 08:36 PM
ccflash22's Avatar
Member
Get back out there and bowhunt some more. Nice find. Get that thing bought and you should be able to trade for a Chevy, as a matter of fact I could probably come up with one.
Kenny
moe7404
Jul 26, 2014 03:58 PM
7T_ChargerBlues
Oct 11, 2012 07:37 AM
RROriginals
Feb 14, 2011 11:56 AM
moparpartz
Jan 28, 2008 10:25 AM
ccflash22
Nov 18, 2007 06:06 AM
