Whats the quickest way to better bhp in a 318?
Old Nov 15, 2007 | 10:53 AM
Depending on the year, but mostly, swapping 340/360 heads onto a 318 drastically lowers the compression ratio, unless you spend loads of money on special pistons.
You can screw around milling heads, which leads to intake fit problems.
Putting a six pack on a 318 would be a complete waste of time, there are far better single 4 manifolds that will give you better performance on that combo
The sad fact is, that the way to more performance is to yank the 318 and find a 360--because 340's are getting rare
360's of course have their own swap problems, the pan is different, you need to change the flywheel for balance.
This, unfortunately, is one of the big screw-ups, so far's I'm concerned, with Mopar SB's, something the Chivvy lovers don't have
Old Nov 20, 2007 | 09:13 PM
Yes but the compression will drastically fall. You'll have to mill the heads to get it back, and may have to mill the intake to fit--at which time you've just ruined the intake for any other use. That's an expensive decision, nowadays.
Old Sep 10, 2008 | 01:18 PM
Monacoman's Avatar
all i have is a great article about the 318 involves some machining but prices arent crazy
http://www.popularhotrodding.com/eng...ine/index.html
dodgenut7
Jun 29, 2011 07:09 PM
old tired rebel
Jun 23, 2010 08:13 AM
crwchf16
Dec 12, 2009 05:44 PM
Valcam
Jun 4, 2009 11:47 PM
Yorkie Mama
Apr 7, 2008 11:33 AM
