727 trans lock up issues
Old Feb 4, 2008 | 07:25 PM
transman037's Avatar
Junior Member
Chris, check to see if there is a restriction in the trans cooler lines, on old chrysler lock up units the converter charge pressure and the cooler out are tied together if you look at a oil chart. bypass the lines temperarly front to rear and see if it stalls, if it does then there is a restriction in the lines or the cooler. if not it is possible that the trans has some internal issues that you'll need to address. Pete.
Air Bubba
Jun 8, 2015 12:26 PM
04 Diesel
May 12, 2013 05:41 AM
jd.fisher
Mar 25, 2009 06:08 PM
Commando
Jan 1, 2009 10:29 AM
rubadub
Nov 19, 2007 11:02 PM
