7 and 1/4" gear ratio?
Old Dec 24, 2007 | 07:08 AM
Geez, just jack up the car!!
I doubt this has a posi, so you'll only need one tire up. Jack one rear up, and support it safely. Get a buddy, or get yourself where you can watch the driveshaft accurately.
Mark the tire, or use the valve stem. If you don't have posi, you can now turn the shaft when in neutral. Turn the shaft once, and the tire will turn "double" the ratio. That is, a 3.23 will turn the tire 6.46 times
If you really want to get "accurate", mark the shaft so you don't get "lost" and turn the shaft TEN turns. Of course now for 3.23, you'll have to turn the tire 64.6 times!!
Old May 2, 2008 | 03:16 PM
if you pull the diff cover, it is sometimes printed on the ring gear. you just have to learn which numbers to read.
BTYM
Mar 18, 2014 10:21 PM
Juice08
Oct 26, 2013 11:43 AM
19newport72
Feb 19, 2013 05:54 PM
mystarcollectorcar.com
Apr 16, 2010 03:42 AM
318scamp
Apr 20, 2007 06:35 PM
