we had the vacuum turned in the opposite direction of the number one plug with the old wire setup which ran fine on the other engine. i did what you recommended in one of your earlier post and changed the number one plug wire to where the rotor was pointing when the number one cylinder was at tdc. Where would i point the vacuum advance? also what do you mean by kickback? and no it does not backfire.
