318/390 Stroker
Old Jan 29, 2007 | 12:40 PM
1 Bad Mirada's Avatar
Administrator
are you looking for 400whp or 400bhp?
Old Jan 30, 2007 | 11:06 AM
Administrator
unless youre set on a stroker, you dont need it if youre only shooting for 400rwhp. im running a .030 over 340 with 9 to 1 compression, small valve heads, good intake and carb...headers...and im making around 380 rwhp. that is with ported stock 360 iron heads, 1.88 intake 1.60 exhaust valves...528 cam, 1 5/8 headers. 3700lb car running 12.40s...imagine if i had a set of edelbrock heads, 2.02/1.60, same cam, high compression pistons, etc...there is no doubt that i would easily pick up 20 more rwhp. i think that the heads alone would do that...no need for a big stroker.
Old Feb 1, 2007 | 04:44 PM
Administrator
those are probably the same heads that i have...
Old Mar 30, 2010 | 04:15 AM
erwin.zeez's Avatar
Junior Member
318 Pistons Dodge Plymouth Chrysler Mopar 318 5.2L Magnum 390 Stroker Piston Sets
The 318 Mopar V8, also known as the 5.2L, and 5.2 Magnum has been around since 1964 as part of the LA engine series and the 1992 and newer Magnum series. We offer a wide range of pistons for the Mopar 318 engines. The 318 is a dependable, reasonably small and light, efficient engine package, that can be built to do everything from power a street work truck to being an all out drag, oval track or road racing engine. Many people tend to overlook the 318 as a high performance engine, which is a shame as it offers many benefits, and the core engines are easy to come by and relatively inexpensive.
In building up a 318, one of the main things that must be changed is the pistons. From the factory, the 318 was just about always equipped with low compression pistons, as it was intended more for long life, using low octane regular gasoline, than for high power output. Installing higher compression, higher quality pistons is one of the biggest improvements you can make to your 318 engine. A stroker crankshaft is another item that really brings the 318 to life as it greatly increases torque and power. The 4 inch stroker crank builds a .030 oversize 318 into a 390 and the increase in performance is dramatic.
We offer a wide range of replacement pistons for the Dodge, Chrysler, Plymouth 318 engines. We have everything from stock replacement pistons, to custom 318 forged racing pistons, stroker pistons and quite a bit in between. The 318 and 5.2L Magnum piston listings on this page include high performance and racing forged pistons at the top of the page, and stock type replacements at the bottom of the page.
Old Mar 30, 2010 | 07:02 AM
old tired rebel's Avatar
It would be interesting to see a build up in the DIY forums here. To see what works and how cheaply it could be done.
Old Mar 30, 2010 | 08:01 AM
Polaradude's Avatar
Dead thread guys, check the date.
Old Mar 30, 2010 | 04:53 PM
1966sportfury's Avatar
A.K.A Bob Dodge
the 318 "LA" wasnt introduced till 1967.
Old Apr 1, 2010 | 06:15 AM
deadkelly's Avatar
ya think we give a sh$t about what you say grant .
Old Apr 1, 2010 | 06:30 AM
Polaradude's Avatar
Bahahaha
Old Apr 1, 2010 | 06:49 PM
I'm glad you put that dead thread in there... I was reading and thinking I have done both of these.... Maybe I need to put my .02 cents in!!!!!! HA!!!!! Thanks Dude.....
Bacto
Dec 15, 2011 04:38 AM
TK1
Oct 11, 2010 11:42 PM
xjonathanx
Sep 28, 2010 07:21 PM
xjonathanx
Sep 25, 2010 10:53 AM
dartswinger84
Oct 10, 2008 12:44 PM
