newb here.. magnum swap into my 340 duster??
Old Jun 1, 2008 | 03:13 AM
are you going to have the crate motor be carb or EFI? From what I have read the magnums and LA small blocks are different so you might have to modify and custom build some mounts. as for bolting up to your 727, I have no idea.
Why do you want to pull the motor out if its a numbers matching? Its worth a lot more with it in it. why not just biuld up the 340? that would be one sick car with a built 340 and 727.
Old Jun 1, 2008 | 03:18 AM
Aslo if the magnum crate motor is just like the magnum motors that came out in 92-03, then the exhuast manifolds will be different along with the intake. If the crate motor is based off of the pre 92 magnum motors, then you should have no problems.
johnboy
Feb 1, 2012 11:20 AM
Morrigan_Aria
Sep 7, 2009 12:20 PM
Morrigan_Aria
Jul 24, 2009 05:21 PM
WailingWallabee
Jul 14, 2009 03:18 AM
rammen99
Aug 24, 2008 01:25 PM
